I'm running on two hours sleep... I'm just functioning like crap.
Ask Tas! lol. he witnessed my complete f*ck up today.
Welcome to my world. If you get this job its like this all the time :D
F_ck up hey...
Do go on,
F_ck up hey...
Do go on,
I've worked in a 24/7 call and radio center.. I know about sleeplessness :)
Let's just say... Don't ever let me touch your sump plug :)
Let's just say... Don't ever let me touch your sump plug :D
That sounds kinky.
Hahaha nice ... *walks away*
Oh AND this is why I need a rear sway bar >.< Got the front today, rear will be next week, hehe! I am currently running JIC Coilovers 10/8's ... I should go 12/10s on track :D
http://i54.photobucket.com/albums/g86/RandomRiki/MSN.jpg
I wish I knew things about stuff and stuff about things.
What you just said made no sense to me :)
Tristan its gods way of saying dont fit turbos before buying ecu ect
yeh - agreed it wasnt ideal, but the original plan was to get the ecu done in a matter of weeks
however shit kept going wrong so the ecu kept getting put off,
its not like i was driving it around - ugh
riki thats a damn land barge, get a rear sway bad and you should loose that, then see about needing stiffer springs
Didn't you read what I said? I am getting a Rear sway bar ... and I have JIC Coilovers running 10ks front 8ks rear and I am going to up it to 12k front 10 rear!!! :D
Edited by Kitty34
Bahaha ... I could do that ... the car is still being set up :) it's good attempting to drift it with each new mod, makes me appreciate when I add something new :) Like I can't wait to put these Cusco solid cradle bushes in on the weekend & my Cusco sway bar + adjustable castor rods :D Then I will see how it goes :D
In other news:
Rims are balanced and fitted. Spark plugs are changed, oil is dropped and flushed, gague cluster is changed, oil filter is changed, fuel filter is changed, blow off valve is changed, pod filter is installed, strut brace has been put back on.
tomorrow = bleeding ATTESSA, filling up oil, installing alarm, installing exhaust.
tomorrow hopefully = registered and driving
:D
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
