Yep very lazy...yawn...
Ah toowoomba not much has changed
I'm about to play my favourite game,
D/L pron at internet cafe, how long will it take til im escorted out. :P
changed since when? you were there last week :)
next time you go to toowoomba, I might come for the drive.
how long did it take to get escorted out?
Edited by Isola
changed since when? you were there last week :P
The fella across the road has a new straw in his mouth. Man that's change
I'll take you up on that.. We'll go up the hampton esk road its nice and bendy :)
hahaha, haven't heard anything from Jason for a while now... must have been escorted out. :D
10 mins boys and the porn wasn't even on screen. God damn porn nazi's!!!!
weak.
In other news, i need a respray soon, anyone know some people that will do a good job for reasonable cash?
Going to go and pick it up shortly.
Really wish the idiots had have called me BEFORE they did any work though. Charging me $385 in labour because it took so long to try and track down a new unit for the fan... which they couldn't find, and wound up getting some holden unit, and that's another $80. If they had have just ASKED me, I would have said 'don't worry about it' bought one from the classifieds or wherever, and plugged it in myself. The fan wasn't even that much of an issue ffs.
Then they tell me a mechanic needs to do the reverse light. That my brake lights work fine (two witnesses say otherwise, as well as me braking outside a window at home every day) and that they've done nothing with the head unit or the alarm.
Not impressed. at all. Really pissed off would probably be a more appropriate description.
So don't anybody ever bother using Chermside Auto Electrical in Boothy Street at Kedron :D
Damn, thats Terrible!
What do they reckon is wrong with the reverse lights? I can't see any reason a mechanic would have to look at it, its ALL wiring except for the reverse switch, which is a switch on the side of the gearbox that takes 2 minutes to replace. Sounds like they just CBF.
What is wrong with the brake lights exactly?
As for the alarm, I'd be figuring out exactly what it does and doesn't do, and get whoever installed it for you to fix it for free.
Head unit... yeah, I guess we'll have to look at that further
Yea... Thats bs. I'm totally against people doing something without letting the owner know about it and then charging them for it. Its like "hey, your motor's f**ked and we swapped it with another 1 we have. That'll be 5 grand please." BS!
It's the reverse switch that is faulty apparently... telling me the gearbox has to be dropped to replace it (bs)
The brake light problem seems to be intermittent. Sometimes all four light up and the spoiler, sometimes the two centers lights up plus the spoiler, and sometimes just the two centers on their own.
The alarm doesn't go off when the boot/bonnet/or doors are opened (when armed) - and the turbo timer doesn't work one out of every ten times the car is turned off (usually when I really WANT it to turn on too).
and yeah, we'll have to investigate further with the head unit, and see if we can work out what's what.
oh, and on the way home the steering seemed to lose power. so that's probably the pump. GRRRRR!
Toowoomba... I'll be heading there this saturday!
Hope no trouble with the cops.
Make sure you don't park at chalk drive and make sure you do come to a complete stop at the top of the range or they'll get ya around the corner.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
