lol. vagmang is possibly an even more awesome word than mang
yep pretty awesome. well mangs can't be manging around here all day some of us mangs have to work..
I just had a manging meeting with a bunch of mangs now I've got to do a manging audit on the mangy manging mang. Then I'll probably mang down to cavill to get a manging feed. Such a mangy day. Mang.
Sup mang ( geoff )
:laugh:
Manging in the office now. 12 hours of manging mangyness. You watch me mang.
oh how i wish i was mangin' at home, watching the cricket
aussies trying to chase another 286 runs today, with 9 wickets in hand. get into it mangs
Edited by Smity42
work should be banned i reckon.
lucky our work has a tv set up, ive been doing plenty of cricket watching today!
Can't watch tv at work to many mangagers. Can after five though. What time does the cricket finish ?
5 or in this case maybe 5:30 if a result is imminent
the good news here is that the tv is set up in the managers office ha ha
Sounds like your managers are cool, mine are karnts
+1
Lucky b4stard!
5 is scheduled finished. They can go to 5:30 if they need more time to get the overs in. And I think it can go even later today (6?) if a result is imminent and whichever team thinks they can win manages to convince the umpires.
+1
Lucky b4stard!
sweet get to watch maybe a hour of it yay
P.S. Bored again now :laugh:. Just wasted 5 minutes doing actual work, and about half an hour writing a hack for Left4Dead2 to let me play it with full gore (F*CK the gubberment!). Now theres nothing to do again :(
P.S. Bored again now :laugh: . Just wasted 5 minutes doing actual work, and about half an hour writing a hack for Left4Dead2 to let me play it with full gore (F*CK the gubberment!). Now theres nothing to do again :(
Can I get a copy of left 4 dead 2 ?
pwease ?
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
