Can I get a copy of left 4 dead 2 ?
pwease ?
Theres no point at all getting a cracked copy as you can't play it online. I bought it from steam on special, it was cheap as (like 15 or 20 bux or something). Totally not worth it for the ghey censored australian version though :banana:. But totally worth it for the real version :(.
surely im more to you than a joining date and a post count :3some:
No, not really :laugh:
I've spent the past hour organizing a work social lunch and salivating over the menu of the Austrian restaurant we'll be hitting up...
Stupid australian censorship crap. Someone needs to take out that dickhead SA attorney general thats holding up the works. Or, if we had American credit cards then we'd get to buy the proper stuff legit. one of my mates does that, gets music and tv shows on US itunes.
... and now I'm off to indro for lunch! later mangs
you actually can buy the UK copy through steam using an aus credit card
...but i didn't know this untill i had already bought the australian copy :laugh:
+1 to taking out d*ckhead SA attorney general though
its getting tought out there in the cricket, even ponting was starting to score quite slowly
The stagne thing about Watson is that he is one of the best hitters i have ever seen, I was in the same team as him at school and from then even into his early career he could hit with the best of them and even in one dayers his strike rate is quite good....but it seems in tests he gets almost anxious about occupying the crease and lock up the attacking shots, if he played his natural game he would be lots better off
URGENT:
Anyone want to play indoor cricket this arvo, 5:45 @ toombul?
It's D grade, so you don't need to be particularly good, but if you bowl like John howard and don't know which end of the bat to hold then don't worry about it :laugh:
I only have the live commentary to go by so its hard to tell how tough it is, but the runs do seem to be drying up :laugh:
No doubt, he is a far better batsman than his test record so far gives him credit for. But when you need to score over 4 an over for a day to win a test match, there's no point farting around blocking 6 overs straight
URGENT:
Well that's me i'm out
URGENT:
oh man id be so keen for this
f**king work
give me notice next time :(
yeh the pitch is taking a fair bit of turn....and the delivery that got ponting out seamed back in from about 4 feet outside off and ended up cramping him for room on a square drive...that was pretty nasty and mostly pitch related!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
