Can I get a copy of left 4 dead 2 ?
pwease ?
Theres no point at all getting a cracked copy as you can't play it online. I bought it from steam on special, it was cheap as (like 15 or 20 bux or something). Totally not worth it for the ghey censored australian version though :banana:. But totally worth it for the real version :(.
surely im more to you than a joining date and a post count :3some:
No, not really :laugh:
I've spent the past hour organizing a work social lunch and salivating over the menu of the Austrian restaurant we'll be hitting up...
Stupid australian censorship crap. Someone needs to take out that dickhead SA attorney general thats holding up the works. Or, if we had American credit cards then we'd get to buy the proper stuff legit. one of my mates does that, gets music and tv shows on US itunes.
... and now I'm off to indro for lunch! later mangs
you actually can buy the UK copy through steam using an aus credit card
...but i didn't know this untill i had already bought the australian copy :laugh:
+1 to taking out d*ckhead SA attorney general though
its getting tought out there in the cricket, even ponting was starting to score quite slowly
The stagne thing about Watson is that he is one of the best hitters i have ever seen, I was in the same team as him at school and from then even into his early career he could hit with the best of them and even in one dayers his strike rate is quite good....but it seems in tests he gets almost anxious about occupying the crease and lock up the attacking shots, if he played his natural game he would be lots better off
URGENT:
Anyone want to play indoor cricket this arvo, 5:45 @ toombul?
It's D grade, so you don't need to be particularly good, but if you bowl like John howard and don't know which end of the bat to hold then don't worry about it :laugh:
I only have the live commentary to go by so its hard to tell how tough it is, but the runs do seem to be drying up :laugh:
No doubt, he is a far better batsman than his test record so far gives him credit for. But when you need to score over 4 an over for a day to win a test match, there's no point farting around blocking 6 overs straight
URGENT:
Well that's me i'm out
URGENT:
oh man id be so keen for this
f**king work
give me notice next time :(
yeh the pitch is taking a fair bit of turn....and the delivery that got ponting out seamed back in from about 4 feet outside off and ended up cramping him for room on a square drive...that was pretty nasty and mostly pitch related!
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
