I'd lay odds on it being the same unit as every other M80. So all u need is a siren and a bonnet switch (should be available from jaycar) and a bunch more black wire to get it to work. Do you have the instruction manual that came with it?
Yeah I have the book. And I'm sure it is the same as the other units. What I'm not sure of however, is if the bastard is actually connected to anything apart from immobiliser points.
hey john
not sure if this helps,
but u might wana contact chris rodgers from Audio express. top bloke and he knows wht hes doin, i got my stuf installed by him, prettty qualifies for this kinda stuff aswell.
hey john
Yeah, as I said before. I'm going to get Chris to fix it all up. Just need to save up some coin.
Looks like rims and tyres and going to have to wait a while :)
yo martin is your ute still rego'd?? i may need to borrow it
astro buddy hows it goin?
hows the 180 goin along?
i need some info on it mate, need to be updated, especially with 2 six packs of pure blonde in the system buahaha
not so over night parts from japan.. but still parts from japan :)
what you doin to to it mate? stock motor and stuff or are you adding more goodies?
yer sme with me the synchros and bearings will take a week to arrive, Dan wil start work as soon as they do, until then car is off the road, well on sat im gona ride shotgun with brandon for the drag to tke vids n shit , apart from that yer of the road until parts arrive.
I've easily broken more than 8 finger bones. +1 eyeball
+1
LOL!
Molly quinn?
Isn't it an M80?
Fingers don't count they're barely even a bone.
my dog just ate my dinner while i wasnt looking f**king flamin mongrel !!!
Dog > Dave?
So anybody else going to the SAUqld dinner tonight? Broadway Hotel? Steak? Was thinking of going up for it since its pretty much a free meal for members :down:
SMS sent but yes, you can borrow at once dad gives it back
im down for cupping if i can borrow the ute hahahah
Whats in it for me though? :)
overnight ute from Japan :down:
I am almost as cool as Japan
laaaaaaaaaate night
this thread needs more uplate action
Sif be up at 2am when I start work at 7
thread needs a good old fashion nut and bolt ho-down party
+1
Edited by Smity42
True :)
Dog > Dave?
Yep, Daves dog is awesome
I would be up for it, but the boss is over from Perth today and will probably want to go to dinner
Just wanted to post this again :)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
