Hahaha i definately <3 those pics too... I put a couple on facebook and got whored by many females hahahahahahaha
I just don't get it....... like, AT ALL. There's nothing appealing to me at all. Ahhh dear.
On another note, do we know anyone with an R34 4 door, plates EIN34? Saw her at aspley about 9pm, I was about to wave, and had a stupid sheepish grin on my face like 'HEY LOOK AT ME I KNOW SAU' and she just snobbed me bigtime hahahaha. Fail.
I hate this twilight shit.
The end.
So I'm probably a no show this Thursday. The car is hiccuping and hesitating like I have a leak somewhere. My other thought it that it might be my injectors, not sure yet. All fluids are fine, temperature is fine, but whenever I accelerate she hesitates and then goes from no boost to full boost, or struggles to hold boost (especially uphill).
I don't want to risk blowing something up, so for now I'm semi offroad until I get some fundage together to get the car looked at. That probably won't be until the new year thanks to the Christmas season sucking away all my money :blink:
So this also means I'm out for this weekend down the coast. And probably out from Wednesday/Thursday meets until I can sort out the problem.
Thats fkd man. Could be the fuel pump too
Hahaha, sorry man. I have a spare r33 stock fuel pump that might be of use? Not sure if it fits the r32 bracket though, but can't imagine it won't considering gtr pumps fit nicely. I dont have the filter though cos the walbro ones are shit which is what I got mine replaced with. Actually.... the walbro pumps are shit in general, worst upgrade done to my car.
Thanks man, I'll see if I can find out if it'll fit. The filter is fine, that was replaced when I got the car.
Tomorrow I'm going to check all my hoses and make sure none are split. Then see if I can hit my cousin up to use his hoist and make sure that I don't have any gaps in my exhaust etc. I'm just hoping that it's not a dead turbo.
Yeah man, no worries. I was talking about the filter on the fuel pump itself. They come with this mesh pocket thing, stock one should be sweet though. Normally you can see oil splattering around the turbo if it's dead cos the seals blow out first. I could be wrong though. If it is dead, be a good excuse for a highflow. Not a major job on your car either :) Gaps in the exhaust you can normally hear or smell them. My money's on the fuel pump or a fkd injector maybe
Edited by yaface
Ahhh good point about being able to smell an exhaust hole. I think I was worrying so much I forgot about that. I never smell fuel/exhaust so that's a step in the right direction.
Highflow? Cat? Don't need one ;)
I'll get into the engine bay tomorrow and double check everything. Do some tightening of clamps etc.
Hahaha, emo much? Summer semester at uni is hommus. Makes me wanna be emo too :)
im rad
when my stock turbo on the 32 was on the way out i had the same thing - itd boost and then nothing at all
i found it slowly got worse the long i drove - like once the car was warm and i started hitting boost it was ok, but if i smashed it/clutch kicked it - after that shot of boost it'd go to shit for a bit
im sorry to hear your misfortune bro - im happy to help where i can
Suitcase full of money? :)
with that said - rb25 turbos are cheap and a great bang for buck upgrade ;)
yeah, the plan was an R34 turbo when this one died. Might be a sooner than expected upgrade
my luck is just bad as yours mate ;) - plus i just had to buy a new engine
nigga what? Was your old one that rooted it couldn't get rebuilt? That sucks man....
I got 'kinda' lucky with my car. Havne't had any problems yet (touches wood), besides a fkd spigot bearing, leaking rocker cover gasket seal, fkd air con bush and a timing belt needing replacement. Cars = money pits :)
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
