hats off to your dedication, to save 45minutes i would pay a LOT lol
Actually one interesting thing about that...
My mole of an ex used to work at Cannon Hill.
I'd drop her off at work in the morning, and then make my way over to work at the airport.
One week I did the gateway (timed each run, counted up tolls and fuel at the end of the week)
Next one I went over the Story Bridge and through New Farm (timed each run, counted up fuel at the end of the week)
I didn't get a single gateway run under an hour, and it cost me more in fuel and tolls. Story Bridge runs took between 27-38 minutes depending on how many red lights I got.
This was not in school holidays or anything either, just normal work/school days.
Oh, and driving through all the suburbs there were school girls to look at. Faster, cheaper, and JB :(
yeah gateway sucks ass, but in the instance where the tunnel was actually faster like you said I would pay, I avoind the gateway like the plague at the moment
Te37s on GTS and GTT look shit, the offset on the fronts is always lame, same problem i had with the really cheapshit impuls on the R32, nice at the back terrible at the front
Agree. But I think all wheels that are staggered width/offset look shite.
John doesn't care about that because he refuses to use toll roads.
I wish I could own a road. Hats off to the scum that came up with them it's nearly as good as the lottery.
i too am a believer to dodge that shit like the plague - but i mean $4.30 for what - 2km?
such a dog act
If it's quicker people will use it.
Baller. Sick life.
Yeah it all comes down to how much you value your time. Even if it cost me $20 in tolls to save 45 mins it would still be worth it. Oppurtunity cost bitches.
I'd just take the cheaper option, even if it's longer. I've got music to listen to :(
yeah i could use that 45 minutes to do some of my on the side consulting work and make $100.....but truth be told i would probably just get on the PS3 :( ha ha
That and I already pay rego. I shouldn't have to pay anymore road costs
I'll agree with youn there :(
But when it comes down to it if the toll road is faster, I'll probably use it if the fee is not excessive. $4.30 is pretty excessive, I doubt I will be using the tunnel much
everyone should boycott tolls for 1 week. to protest the price.
remind me to stay off the road that week though.
someone start a facebook group about it. see how fast 92000 people join :(
Kinda like the petrol boycotts. If you actually got EVERYONE in the state/country to do it it might work, but otherwise its just a waste of time.
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
