all i can say is that i have 18x10 +12 and they barely fit!
Ah k
http://www.1010tires.com/WheelOffsetCalculator.asp
You can get the specs of your current wheels and compare them to the specs of the wheels you are looking at buying, to get an idea of where they sit
Yeah I cant remember what o/s my current rims are so Ill have to wait till I get home
18 x 10.5 +22 will sit a little further in. Should fit with a little bit of work. Check out the Offset threads in the cosmetic forum. Will give you an idea of what will fit and what won't.
Yeah Im hoping that with a little help from my old mate "Mr adjustable camber arm" we will squeeze em in :)
:rofl:
tim you need to post more
Yeah.....I'm a bit slow...some of us have to work instead of post-whoreing..... :)
f**k you Timmeh, im kicking you in the nuts next time we meet
Bahaha that's the first laugh I've had in relation to that show! Your place or mine :(
Yeah Im hoping that with a little help from my old mate "Mr adjustable camber arm" we will squeeze em in :(
Increasing camber at the rear...in a rwd car for the sake of fitting bigger wheels seems a little counterproductive to me!
Bahaha that's the first laugh I've had in relation to that show! Your place or mine :)
mofo
[ ] News worthy.
[X] Lawn bowls sucks
I went once on a Sunday arvo, got blind and had a great time . . .
Buuut without beer and sl*ts, your right, it does suck :)
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
