Never got into dexter....... what's it about
Dexter is a serial killer who cleans up all the murderers that the police system can't process because of loopholes in the system (illegal search warrants, tainted evidence, technicalities etc). He works with the police department as a blood spatter analyst and uses his position to get the info on all his victims.
It's quite a good watch, well written, brilliantly cast and keeps you wanting more and more. I slammed through the first two seasons in two and a half nights. Had no sleep and was functioning solely on V and coffee at work, total autopilot.
Season 3 was a one nighter, and Season 4 I just did over the last few days as a couple had to be downloaded again. I was not a patient person while waiting for them to download a second time... there was quite a lot of "The chili cookoff is happening right now! and i'm missing it!" dancing going on.
Worth checking out at least the first season if you've got the time.
BRRRRRRIIIIIIGGGGGGGSSSSSSSNNNNNSSSSSSTTTTTTRRRRRRRRAAAAAAAAAATTTTTTTTTOOOOOONNN
NNNNNN!
FYP
BAHAHAHAHAAHAHAHAHAHA! Imma paint it in John Deere colours and put an SR20DET badge on it
Taken care of :banana:
Dexter...blah blah blah
Hell keen! Sounds like a good show
do it mang! this series is just... chilling :(
And then burn a copy for me!
FYP
lol
If only you really were joking :(
yer :(
morning bitches
morning, my serbo-croat brother
ATTN: Tristan
Dude, might have a spot for you to play tonight if you're keen. Grand Final, beer at stake.
Not 100% sure yet, but just giving you more than 3 hours notice in case you're available. Let me know :banana:
The dirty sl*t ALWAYS wants to haul a big load. When/Where/Why/How/Who?
Need to take a fridge from Stafford to Aspley.
And Tas made mention of a GTR bonnet I might be able to get - Not sure where that's coming from, but it would also be going to aspley
:banana:
$100 brand new on ebay.
second hand ones tend to break.. If your keen I'll get one spilt postage or something.
Thanks for the offer, but that was more to let her know there wasn't one. I decided I'm not going to bother sourcing vents until I fix the AC. unless I happen to see some for $20 that is.
Once I've got the AC working, I'll replace my center one (I broke it the other day... long story) and buy a passenger one. So if you're still after one then :banana:
I'm sure there's SOMEONE who'd go halves though. You could probably even do a group buy for them! Enough people seem to need them!
