i was jst kiddin about the moslem part guys, ive had my fair share of the punani bck in the good old high school days but havent relly found the time once i got to uni, even if i do score im too pissed to remember anythin the next morning, need to sober up, this sem is going to be extremely stressful.
is it just me or can i hear a cricket chirping ?
*face palm*
fag
No u.
Side note :
Job application I just sent
[more stuff here]
I'll let you know if I get anything back :)
That is quality posting right thur.
cant do until im married, muslim bro lolz,
porn is all us moslems have before we get married ;)
Sucks to be you?
Hahaha, pretty sure the koran says you can't drink alcohol either.... May as well break another rule...lol
No wonder they all blow themselves up.
if the hymen doesn't break, you can't count it on the score card :)
Farkin lolskates.
morning mangs
hi colin, hi josh
Sup biznitch.
I took the filter off my phone line last night and got 800KB/s dload but when downloading from anywhere but speedtest it's still slow as f**k. Going to call TPG tonight. Couldn't be f**ked last night.
Sup biznitch.
Are you talking normal downloading or torrents/p2p. torrent speeds can depend on a great many things, so might not be a problem with your line.
f**king score. I got Monday off. Win.
Same. sexy time?
morning mangs
hi colin, hi josh
Morning ;)
Sucks to be you?
lmao
I hate u
Same. sexy time?
Jealous
So whos the best person to talk to in regards to pumping gaurds ? I dont really wana do it but 5000km from a set of bridgestone potenza's isnt really good on the wallet ;) Also once the coolers on ima need the extra rubber on the ground :)
Same. sexy time?
normal dloading is still slow which is probably normal. Haven't tried any torrents/p2p yet. Probably just shit servers that I'm dloading from rather than my line. Gay.
http://www.guardrolling.com.au/ that is the guy that I used to roll my guards. Not sure if he's any good with properly pumping guards. I would probably go see a panel beater if it needs to come out a fair bit.
So whos the best person to talk to in regards to pumping gaurds ? I dont really wana do it but 5000km from a set of bridgestone potenza's isnt really good on the wallet :) Also once the coolers on ima need the extra rubber on the ground ;)
I has a hammer and pliers :)
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
