lol, canteen wouldn't accept my 10c coin as its 'not australian'. turns out to be some arab coin. Whats the odds its worth about a million AUD?
Did you and Brizzy rocker do alittle hokey pokey?
Also..... anyone have experience with haltech or emanage? I can get an emanage blue for pretty cheap off a mate, but apparently they're a pain to install + tune (anyone here know someone who can tune them?)
On the other hand, I know nothing about the haltechs.
I was wanting to install myself, I'm pretty handy....... but won't be able to tune.
Debate......... NOW!
No contest, Haltech pwns
cricket this arvo :domokun:
awesome
i hate it when its on at the gabba, bugger off people these are my pubs! lol
you live in woolangabba? :domokun:
ps ur a dog
work in Wooloongabba! Live just down the road in Yeronga
PS i know right! I was still at work at 7:00 so no icecream for me
or just source a A'pexi PFC and hando commando since its just plug and play..
FAIL
Still tossing up if I want to head in after work today. No one wants to go with me since its $57 a ticket, but I can go in for free, and hit up the German club too. Tempting
power FCs are so 80's
+1
how very interesting indeed
you know where ill be when u get peckish
wtf u fags on about who said anything about tuning with a HC ? lol tard
obviously if moist sack is complaining about $6 in coins
then he might be wanting to do things on the cheap side
this made the impression that all you need to do it plug it in and play with it yourself and the car will be tuned
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
