lol, canteen wouldn't accept my 10c coin as its 'not australian'. turns out to be some arab coin. Whats the odds its worth about a million AUD?
Did you and Brizzy rocker do alittle hokey pokey?
Also..... anyone have experience with haltech or emanage? I can get an emanage blue for pretty cheap off a mate, but apparently they're a pain to install + tune (anyone here know someone who can tune them?)
On the other hand, I know nothing about the haltechs.
I was wanting to install myself, I'm pretty handy....... but won't be able to tune.
Debate......... NOW!
No contest, Haltech pwns
cricket this arvo :domokun:
awesome
i hate it when its on at the gabba, bugger off people these are my pubs! lol
you live in woolangabba? :domokun:
ps ur a dog
work in Wooloongabba! Live just down the road in Yeronga
PS i know right! I was still at work at 7:00 so no icecream for me
or just source a A'pexi PFC and hando commando since its just plug and play..
FAIL
Still tossing up if I want to head in after work today. No one wants to go with me since its $57 a ticket, but I can go in for free, and hit up the German club too. Tempting
power FCs are so 80's
+1
how very interesting indeed
you know where ill be when u get peckish
wtf u fags on about who said anything about tuning with a HC ? lol tard
obviously if moist sack is complaining about $6 in coins
then he might be wanting to do things on the cheap side
this made the impression that all you need to do it plug it in and play with it yourself and the car will be tuned
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
