but it is MORE baller...which is exacly what i said
you need to discuss the finer points of ballerism with Josh like i have
Since when is Josh the authority on ballerism? Skinny pr*ck wears girls jeans and drives a smart car. Unballer.
They're boys jeans
and all my cars are famous, which make me the authority
I think of bumbul bee tuna everytime i see you post
They're boys jeans
I shall not respect your authoritah.
He also purges. You can't purge and be baller.
QFT
lol!
Maybe he got attacked by some true blue f**kin strayens on the weekend?
Quite possible. I saw him on sunday (or was it saturday? long weekend is long) when he dropped round the AC unit. Maybe his home is zombie proof but not bogan proof?
Me neitha!*
*intentional 'strayenism
Anyone know how to get off the ghey willowbank sms spam list? I don't even like motherf*cking drag racing... ;)
c*ntus's sent me a msg too....i also want out
I used the "Contact" page on willowbank's website and asked to be removed, and apparently they are actually going to do it :(
how am i the first person to make reference that we made page 800....
Needs another 200 to be significant
Stop posting pictures of yourself, you camwhore
Goes without saying?
indeed
Edited by Smity42
be that as it may....all whores use 40ppp, and is hterfore the point of truth when claiming page ownership ect, true story
there was even a 40ppp noob emoticon for such times as noobs on 20ppp claimed a page incorrectly, then we were not allowed to tease people anymore and they took it away
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
