that would be gossip girl
Is there anyway to make the pain stop?
Did you checkout bodyrock.tv ? that is a fit sheila right there nice vid's
no, and no.
In other news however, I am making a grated cheese and scrambled egg sandwhich.
no, and no.
damn was hoping there was a way.. i'll just have to push through the pain barrier.
yum... toasted ?
no! toasting it would cause the ketchup matrix to destabilize!
and we don't want that to happen
a/c panel at work says
Sleep mode Z z z. Push any key to wake up. *push*
Push the Logon button to gain access. *push*
No Access ! *flash flash*
How gay is that ?
How gay is that ?
maybe it's meant to say "strike any button meanacingly to gain access"
maybe the buttons are insufficient for an instalation of that size?
maybe. *goes off to find more buttons of equal magnitude*
if only I had tabasco sauce... tabasco sauce would have turned this sandwhich into a winburger!
mmmmmm.....winburger....
Does that come with fries ? :P
damn! you just reminded me I had potato wedges! I should have fried some of them up. They would have been awesome with my winburger sans tabasco sauce
get some of those big ones that launch nukes :P
Gots thrice of them... is that going to be enough to win against this diabolical a/c unit ? I think not
would be very greto wintatoburger :down:
winburger wedge famiry size special! maxus greatoo! :down:
I is hasing the organic leak, pumpkin and spinach resoto. Very not greatoo.
Extra farty goodness though :P
I already finished off my - Chicken, corn, carrot, potato, pea, mushroom and onion soup before. When Dan was still with us.
Side note: Searching "Super Asian" on Google with safe search off is just awesome :down: greatoo image find!
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
