Morning mang
Im guessing here, but i reckon the 88/88/80 is the amount of dish, and the 51/39/31 probably has something to do with how much brake clearance you get...
EDIT: Or possibly the other way round...
Cool thanx :)
It's still 5.7L's of pushrod shit.... If you'd want a v config motor that's kinda unique go the vq30det. 210kw's and 386 Nm @3600 rpm from factory :)
Such hate for the LS1s I never understand. Old donkey tech but it works well and it's pretty well packaged for what you get.
Can someone please look at this picture and tell me what the highlighted areas represent?
the A B C numbers refer to the disc type of the wheel which is related to brake clearance and the 88 88 80 refers to the amount of dish.
No tractors, no emos, no SAUQLD peeps, no boats and no gabnrs :(
Just a croat and some etcs. f*cking weak effort guys :D
+11ty
Morning mang
Right the first way round.
f**kin wicked thanx mang :)
I'll never understand how someone can rate an old oil burning, pushrod piece of shit that feels like it has turbo lag despite being a v8 (seriously drive an early model VT one) yet bag an SR
I bag SRs cause I know you guys like em ldo. Driven later modeled ones and they didn't feel laggy to me. I haven't driven many other v8s other than dads xr8 and a couple of dirty commodores but they didn't feel that much different. Dad's is a quad cam 32 valve v8 and it's a bit weird. It never feels like it's really going until you're up around 3500-4000rpm which I think is weird for an 8 but it still pulls hard.
I think the positives outweigh the negatives for the LS1 it's a pity they've never put it in a decent car. Opinions differ on this point obviously but meh.
I only bag the SRs coz I secretly like them :)
IF (and I stress the IF) I was going to put a 4 banger into something, it would either be an SR or FJ.
stoopid poms... :D
It's always about engine size with you boys :(
Boys and their donks...
If i was going to V8 anything and i couldnt afford a BMW S62 from a M5 i would have to use a 1UZFE, 6 bolt mains FTW
+1. VH45s are also nice if you want to keep it nissan
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
