Morning mang
Im guessing here, but i reckon the 88/88/80 is the amount of dish, and the 51/39/31 probably has something to do with how much brake clearance you get...
EDIT: Or possibly the other way round...
Cool thanx :)
It's still 5.7L's of pushrod shit.... If you'd want a v config motor that's kinda unique go the vq30det. 210kw's and 386 Nm @3600 rpm from factory :)
Such hate for the LS1s I never understand. Old donkey tech but it works well and it's pretty well packaged for what you get.
Can someone please look at this picture and tell me what the highlighted areas represent?
the A B C numbers refer to the disc type of the wheel which is related to brake clearance and the 88 88 80 refers to the amount of dish.
No tractors, no emos, no SAUQLD peeps, no boats and no gabnrs :(
Just a croat and some etcs. f*cking weak effort guys :D
+11ty
Morning mang
Right the first way round.
f**kin wicked thanx mang :)
I'll never understand how someone can rate an old oil burning, pushrod piece of shit that feels like it has turbo lag despite being a v8 (seriously drive an early model VT one) yet bag an SR
I bag SRs cause I know you guys like em ldo. Driven later modeled ones and they didn't feel laggy to me. I haven't driven many other v8s other than dads xr8 and a couple of dirty commodores but they didn't feel that much different. Dad's is a quad cam 32 valve v8 and it's a bit weird. It never feels like it's really going until you're up around 3500-4000rpm which I think is weird for an 8 but it still pulls hard.
I think the positives outweigh the negatives for the LS1 it's a pity they've never put it in a decent car. Opinions differ on this point obviously but meh.
I only bag the SRs coz I secretly like them :)
IF (and I stress the IF) I was going to put a 4 banger into something, it would either be an SR or FJ.
stoopid poms... :D
It's always about engine size with you boys :(
Boys and their donks...
If i was going to V8 anything and i couldnt afford a BMW S62 from a M5 i would have to use a 1UZFE, 6 bolt mains FTW
+1. VH45s are also nice if you want to keep it nissan
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
