So I sat at home, waiting for Telstra to once again come out and fix up the bollocking they did to the phone line. "We'll be there between 10 & 2" so I've been here, all day... waiting. I call them up at 5 past 2 to ask what's happening and they say "No that's booked in for the 23rd, not the 22nd". So awesome that they booked it in for the 23rd and told me 22nd. It's just lucky I don't have a job to go to!!!! :thumbsup:
martin did you end up buying rascovs car?
No, If you followed the thread properly you would know this :thumbsup:
I was trying to organise to go and look at it on the weekend, but it was proving difficult because it was at his fathers place (past d1ckswich), and because he already had another bloke interested (another guy from the 31 club, lol). In the end I offered to come look at it sunday and bring cash + car trailer with me, so then he rang the other guy and it seems he's committed to buying it. So I miss out :D
I like this idea better than cardboard <3
Group Buy?
Welcome to telstra. Felt so good giving them the boot and going to naked DSL...
Group Buy?
I'd be in for a group buy. Can you make an Emily one too? And a Molly?
What naked plan did you pick? I had a look at them but they all look like shit plans.
and:
Edited by Isola
you're naked?
buttsecks?
keen.
You don't ask much do you? Spose I'd better throw a Grace one in the mix too...
http://www.tpg.com.au/products_services/ull_pricing.php
I'm on the $60 one. Its $10 dearer than the equivalent non-naked plan, but remember you DON'T PAY LINE RENTAL ($30). Install fee is a bit dearer, but you come out ahead after a couple of months. Only catch is, you need to have an active phone line (on telsta infrastructure) when you sign up, otherwise you have to pay about $200 to connect then disconnect one (I think I managed to avoid this by transferring my account from st lucia to petrie, thus avoiding all connection and disconnection fees). They haven't charged me any fees that I've noticed anyway...
and:
This picture won't load at work. Hopefully that means its good enough to get blocked by the filter, and I'll get to look at it when I get home :thumbsup:
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
