where are the ladies at?
tomorrow i get to work on this:
i like my job, also might be time for me to step sideways within the company......
Edited by Dan_B
anyone know a Simon Cordwell? just rocked up to my sis old place, and we dont know who he is. and and knows alot about my sister...
he drives a white 34. thats about all the info we got
shaun knock him out and steal his wallet and car, i know some people that need some 34 gear......
P.S. get the coupe of yours on the road asap, i want to do a photo shoot with martins coupe
i would of, but he hasent come to this house yet :P.. o and i can use some 34 bits to... and i cant find him...
its on the road... but for some reason... my turbo doesnt build boost *cries* so dont like driving it
but mine actually looks good :P
No pics tonight John, had jailbait over and now cbf. Tomorrow if you're lucky.
beat downs? :P
i'd like to find out who he is and what he wants... then see what the response will be :(
i owuld say shot gun rims but i no longer have any use for 5 stud :P
replacing a battery on it and working out where the current draw is coming from in it.
Poms shouldn't be let loose on electronics
http://www.facebook.com/profile.php?id=171...2.3400005810..1
http://www.facebook.com/profile.php?id=587...2.3400005810..1
Dunno if either are your man..... doubt it actually
They do it wrong ?
already sus'ed fb haha, cheers for looking though.. cant hide for ever
to rite about that eletrical stuff dan..
so many british cars have stupid wiring and flaws
Edited by red_screamer
awwwwwww :P
oh... speaking of JB. That chick I posted a pic of ages ago with the huge rack and the tongue ring. Who wants to see her lick her own tits? :(
Edited by Isola
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
