Rule 1 - Martin is always right.
Rule 2 - If Martin is wrong refer to Rule 1.
:D
sig'd
unless u own a KFC somewhere i think they're kind of lame. But if u like em go for it.
LOL. +1
Hmmm well I do like KFC but I defs don't own one... I kinda like the idea of passing someone..... and being all like ZINNNNNNNNGGGGGGG
need pics of your car with new stickers :D
Yeah I havnt put em on yet cause every time I went outside it was raining :D
Will do it for sure when I get back next week
OMG A GABNR!
from memory its a mythical japanese dragon like creature with 8 dicks, but only 15nuts or something
it eats godzillas for breakfast
micheal knows more about it than i
This is true, Ive seen one
Havnt u got any on your car yet ?
nooope shes totally sticker free
have a few waiting, waiting for better weather and for when shes driving again :D
:D
sig'd
LOL. +1
That reminds me I need a sig...
I can imagine you doing that as well lol.
Sup boys :D
Mang *tips hat*
My suggestion:
Lol good call.
Martin/DanB/Anyone else who might have an idea. What other options do I have for brakes on the 31 if I want to use the S13 suspension? Will 32 hubs n shit bolt up to S13 suspension or am I way off. Such a pain in the arse trying to get hubs n knuckles off someone.
dear colin
<3 astro
<3 long time. Funny thing is as soon as I posted that up I found somebody selling them on SD as well lmao. How much you reckon is fair for all that shit? Was thinking like $250-$300ish? They're only shitty 4 stud stuff anyways lol
umm i have no clue man, but as you say they are 4 stud, no one really wants them - defs an item to negotiate on
whats the SD dude want?
no idea. His stuff is still on the car. He is doing a 5 stud conversion so will sell them once they're off. I've seen some sold on SD for like $150-$250. I put an offer on boost lol. Should of made it less i think.
