It can be fixded ? or lots of monies ?
Wow.
I just had a idea.
If you don't like the hot air blowing in your car you cold just remove the heater tap. That would mean that you wouldn't have a heater in the car for winters time.
;):thumbsup:
Wow.
I just had a idea.
;):thumbsup:
well I need to be able to cycle it from hot to cold to use my demister
pfffttt
seeing the road is for noobs
you might be lucky. I removed the heater tap actually what i did in my old telstar was disconnected the heater hoses from where they entered the fire wall and reconnected them with each other. Apparently that bypassed my heater tap. I shouldnt have had warm air in the car when i put it on heat... but i did. I also didnt have hot air blasting in all the time.
pfffttt
:thumbsup:
How many sports does Red Bull sponsor or are involved in?
Just watched some Red Bull ultimate break dance championships.
Is it just me or do they dance like bugs that have been sprayed with mortein and are in their deathrows ?
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
