You're the kind of guy that in the days of yore, bards would have written songs about, and sung of your tales to their fellowkin over pints of the town's finest ale <3
I went through that thread, and a few things I googled. It appears my little trap door servo is of teh rooted. I seem to have rigged something up for now (cardboard isn't flammable isn't it? :blink: ). The test shall be shortly when I have to go out, and the engine is running.
I actually got awesome temp readings from all my sensors, so maybe all I need for my AC to work is a new compressor :)
glad it was helpful mate!
I have earth tones on today
ohk ohk well so we dont match ill go for shallow ocean blue turtle neck with a pair of arctic ice shelf pants
Did you just ask the closest female for the most gayest items to post
lol :)
im in the computer lab - i came up with that shit
i got another one,
when we are out i can get a 6pm winters sky navy scarf to compliment turtle neck
lolzz
my lunch was good, aside from the fact that a work mate spilled 2 schooners in my lap....but i got to come home so i guess that was win after all!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
