You asked me:
Dick In Ass, Gooch f**ker?
I'm quite comfortable being able to sit down without a hemorrhoid doughnut, so I said no thank you :)
You must have dicks, asses and gooches on the mind.
DIAGF = Die In A Grease Fire.
done ages ago never bothered to pick it up.. lol...
neg just new under body parts..
trying to find those air ducts that 32 33 and i think 34 gtr got... next to the rod ends.. otherwise i will have to fab up some..
Wreckers? They would be fairly easy to make. Fibreglass ftw.
Mmmmm I know what you mean. I think I'm gonna have to be careful once I land a job to NOT go stupid on little expensive pieces. The only money I'm really prepared to throw at the 32 is a paint job, and an engine transplant (and related items. fuel pumps etc). Apart from that I have to start saving for my 34 once I'm working again!! :)
ENGINE CONVERSION!
ZOMG RB26
i <3 JOHN
My money is on a Civic or FC
idk, possibly an evo (if still serious about time attack)
all 13bs are suited to rebuilds lol :P
lolz! quality post
No, I am not going to hunt back through and find it for you, but in the classifieds somebody had a set of the inner guards with the ducts for sale. I think he was in Melbourne.
ENGINE CONVERSION!
ZOMG RB26
i <3 JOHN
Evo is a good shout as well mmm...Anybody want to get a betting pool started?
lolz! quality post
<3
You just be incredibly.... flaming :P
lmao nice :)
If I do a conversion, it'll be an RB25, or a VG30 twin turbo.
*facepalm
i was giving you big love there bro and u just killed me
are you going to strip the car and get all gtst running parts?
awd car = awd motor, hence rb26
like im sure it is possible to do it with a gtsFO - but i mean wouldnt it be easier to sell the FO and get a cheap gtst and do the conversion, or buy one with the conversion already done?
*facepalm
the stagea RB25 fits easily in a GTSfo
I have a soft spot for the 6s. One of the other cars I was looking at before I bought the GTR.
yeh 6s have always been my fav too! i wanted an evo 6, then wanted a gtir, then r32 lol
still want a GTiR - maybe when i finish uni, itll be a rad little car - stockish motor and and cronic suspension
VQ35DETT over a VG tbh. If you were going to do something awkward like a VG you would have to be mad to go past the VQ engines.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
