Piping engine mounts ect, and how do you graft the awd to the engine? the front diff is more or less in the sump so i imagine there would be some tricky work to be done there
My sump can be modified and used for the VG. I'll have to wait till Dan reads this to find out about mounts and piping, but he said that overall it's much of a muchness between doing the 25 and doing the VG.
Colin. I can NOT afford a VQ turbo. Plain and simple, I just bloody can't. Yes it might be more jizzworthy, but I simply cannot afford one, and am not throwing that much money into the 32.
anything over 250awkw means broken diffs and gear boxes, and the gayest part about it is that there is no good aftermarket alternative so you just have to keep feeding it stock bits
That is gay. They must of solved this problem in the later models as there are a few of them running some pretty serious power with GT35rs n whatnot..
sif start talking about interesting stuff just as i have to go home
haha I know what you mean. I'm trying to get this shit finished before I leave but I just keep checking this thread lol :)
If all the stock stuff fits then you should be laughing. Fair enough if moneys tight. Do a VH instead :P
If all the stock stuff fits then you should be laughing. Fair enough if moneys tight. Do a VH instead :)
Yeah, by the sounds of it, that's MOSTLY the case. But I'll see what Dan says :P
Rego and insurance costs say no to VH :P
seriously though if money is an issue and you plan on selling it anyway...just get a r34 turbo and computer with the usual exhaust and stuff and make 300hp for much less
nope, got worse, the active diff is very prone to breaking and the 6 speed box is pretty shit too! the guys with the 35Rs are the dudes i spoke to, one guy out at qr was on gearbox 3, rear diff 4 and front diff 3. Once they come up with a solution i might think about getting one!
I want to keep the 32 for track duties once I buy a 34. So I was thinking if it's got a 300hp motor sitting in it already, then I can play around adding more power once I've got a place to use it legally.
Money isn't so much an issue, it's more than I don't want to dump a fortune on power upgrades when I'm not using the power. I won't be using 500hp on the street, so I'm not going to use money I could be saving for my 34 to get it to 500hp.
that sounds shit lol. f**k that lol
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
