What you getting from there?
some steering rack bushes :)
You going tonight Jason? Or working? If you're going, wanna drive over together? I gotta give you back your socket and ratchet, and we should limiter bash a tunnel on the way there :D
rb20 <3 limiter
You going tonight Jason? Or working? If you're going, wanna drive over together? I gotta give you back your socket and ratchet, and we should limiter bash a tunnel on the way there :)
Am i going ? Yep :(
Sounds like a plan. In for the tunnel :D
Am i going ? Yep :)
Sweet - meet at your place? What time?
Damn I hate failing at life :(
awwww we still <3 you :)
Have you had chance to resize that gif yet ?
It's not about having a chance - I need my other computer with all my graphics programs on it. Don't has other computer here. It's buried under boxes of stuff at my Mum's house.
p.s. Why the f*ck are my posts going on top of the quote ? :(
Because you don't know where to put the cursor?
it's called "failing at life" :D
+1 :)
What needs to be done? Just resize a gif? If its not animated send it here I'll do it...
