Here is the flow chart.
Morning peoples
*HEADSPLODE*
Apparently I am dead, but at some point made sweet sweet love to a promiscuous co-ed while barricaded from zombies in the food court KFC and it was totally worth it :)
My friend in the white shirt and I went home with all four
If true, yes indeed you are the winner.
Picsorban.
However, we still haven't determined if Tristan and co fail at the English language, or just fail at life...
Picsorban.
Nothing worth photographing happened.... will work on it this weekend though hahaha
Not understanding this?
^^^ id argue fail at neither...
yeeep
I'm agreeing with you
trust me i have run ravi thru a his pep talk, he is looking calm, focused and completely understands his task at hand
work shall continue, and i would argue, should be completed by the weekend
which means that we will see bewbs sunday night... or unfortunately there will have to be a ban ravbat..
I think this should be on every page
I may even have it as my sig...
How hot was the fifth woman ? The one behind the grassy mole. :)
I mean the one we can't see.
and im trying to say chick B is the hottest - hottest you can see
chick "Z" as i call her, is the hottest - but ravi needs to post up a better pic of her
Quoted just so I can look at it again :D
Thankyou Colin, I appreciate you saying that about me.
Corrected, and thankyou for even putting me above 5 AHAHAHAHA.
She really is smokin hot, she just wasn't in the mood for photos at the time.
Ain't too bad yourself mate ;)
YW Ravbat :)
see i dont kno - i think the girl on ravis right looks the hottest
Number 2 right?
I'd go the one on Ravi's left (Right of Ravi in the pic)
Number 4 right?
marto a simple "+1" or "tristan lets double team her" would have been fine
I would like some eiffel tower love
+1
our right, ravi's left. long brown hair. that chick = win. all the others can be thrown back.
Number 4?
This post is useless without pics.
B omg
QFT.
I stand by my original statement of 2, 4, 1, 3, 5.
sif B
C is teh winnar
dude trust me when i say, the 5th girl you cnat see is the hottest
Chick B looks like she needs a steak or 11ty
I demand pics of chick Z
Me too
She has a nice hand :)
Guys what we're doing is silly. Clearly in order to make an educated decision we require more information in the form of BEWBS! Deliver Ravi otherwise I won't be the little spoon anymore...
Hahahaha well Tristan's been mentoring me so this weekend hopefully we'll have some BEWBBBBBBBS to report in with hahahaha
Having said that, I'm not sure how good T-dawg is with the ladies :)
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
