An interesting counter argument. But, I put it to you sir, you sucked off a horse.
Well put sir, however:
Ladies and gentlemen, this is Chewbacca. Chewbacca is a Wookiee from the planet Kashyyyk. But Chewbacca lives on the planet Endor. Now think about it; that does not make sense!
Why would a Wookiee, an eight-foot tall Wookiee, want to live on Endor, with a bunch of two-foot tall Ewoks? That does not make sense! But more important, you have to ask yourself: What does this have to do with this case? Nothing. Ladies and gentlemen, it has nothing to do with this case! It does not make sense! Look at me. I'm a lawyer defending a major record company, and I'm talkin' about Chewbacca! Does that make sense? Ladies and gentlemen, I am not making any sense! None of this makes sense! And so you have to remember, when you're in that jury room deliberatin' and conjugatin' the Emancipation Proclamation, does it make sense? No! Ladies and gentlemen of this supposed jury, it does not make sense! If Chewbacca lives on Endor, you must acquit! The defense rests.
I know how to settle on a winner.
Who's the guy in the photo? There's your winner right there :ermm:
there's a guy in that photo?!
Hahahaha well Tristan's been mentoring me so this weekend hopefully we'll have some BEWBBBBBBBS to report in with hahahaha
Having said that, I'm not sure how good T-dawg is with the ladies :)
Seeing as how tristan always promised to bring us scene bitches and never delivered... and never gave us bewbs... I'd say you're probably going to get slapped this weekend :P
nah im flagging it, that was hard lol
that's what she said
you suck
no you suck!
that's what she said in return.
after a brief tickle fight... they sucked it together.
It looks a lot like my old 32...except a shitter blue:P Oh and i had far cooler looking brakes :ermm:
Its not about the going home its about the nailing the ass out of them when you get there, if this wasnt the case this story and excitement needs to end now because it saddens me
1. Thinking I might have to paint my callipers when I get my new rims.
2. +1 doesn't even begin to agree with this statement
I really wanna paint my calipers too, just really cbf doing it. Any recommendations on paint brand etc?
Can't really make out the purple in that picture, so they can't be THAT gay.
PS - what are those side skirts?
yeah pic is too fuzzy, in real life they were pretty bad
i think the skirts were a factory option or somthing, lots of GTSTs have them, i think they mostly came on the ones that had the cool mechanised front lip, we call them Mspec but i dont think thats what nissan called them! this car here has the same ones, as did many others when i had a quick google image search http://www.mashamoto.co.uk/be/image/Sold%2...09/CIMG0950.JPG
Coooool! I like the look of those. I like the look of that front bar on that one in the link too.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
