And on the second day God said unto John PUT THEM ON THE CAR BIATCH. And through God's fury John saw the light and all was well.
And on the third day God said "Silence the dirty ranga!"
and God saw that it was good.
and on the fourth day. God said "Needs more low". And John said unto God...
"Niggah please! You pay for it!"
Dear Martin,
here is my "blueprint" for my BOV shield that I was trying to explain.
As you can see, it lets more air through, but still not enough to totally let the valve open and release all the air before it goes back to the turbo, enough that it would probably avoid a full flutter though, and just do a flutter dump and make it a stuttering hiss instead of a sigh.
One day when I'm not lazy, and can steal Jason's tools again, I'll give it a go and tell you if it works.
Big <3s from your Advan Brother
im so f**king dnrunk omfgggg
i <3 SR and everyone who helped me put it back in for the 2nd timeee
omg this sceen is f**king ubrly as f**k
ps <3 marto an dan and dave ooomg
I has an angle grinder...
Gaids :D
+1
Just got home/ going to bed/ updated my sig poast!
I got home and thought about your sister, that UPdated my post :(
what about the beer and the chainsaws?
+1
Dear Martin,
Mine does not have that bevelled section or the second hole (from memory anyway). It's just flat, like the Left hand side of yours in that pic on both sides. Strange, maybe mine is actually a 32 item or something. Wouldn't surprise me, that sped Erin ripped me off on the motor I'm sure he wouldn't be averse to putting a few 32 bits on there...
<3 Brother
P.S. Thats now officially 2 cars that I think look good on advans :blink:
Marry me, you sexy beast
Edited by Smity42
Martin, if you need some one to fix your paint up let me know!
Thanks Mate, yeah I definitely will if I can't sort it out!
He should definitely repaint the filler panel for me: if I wanted paint with runs in it I could have done it myself!
The front bar might be more of an argument, since theres nothign really wrong with it other than being a very average job :(. Might need to get your mate to re-do it for me, I'm not going to hand over any more money to this guy.
cool not a worry
John those wheels are lookin good........ and yep needs more low now hahahaha = $$$ :(
Tristan you are a god <3
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
