name='Isola' date='28 Mar 2010, 02:22 AM' post='5153241']
there's no keener kind of keen!!
If only there was... it will always be the dream.
Avatar... fern gully
Same thing ? :O
For Tristan:
How to properly repair rust, something which whoever did the dodgy-ass job on your 180 should take note of (Note: not the job Dave did last weekend, that shit is legit. I am talking about whoever did the original abortion). Bought to you by Garage 31.
Step 1: Actually remove all the rust.
Step 2: Apply paint. For best results, this should be the same colour as the original paint and done by someone who knows what they are doing. But at the very least paint it with something, to prevent MORE rust.
Step 3: Profit.
Result:
Big thanks to Dan for coming and doing the major bits of painting last night!
After lunch, all the panels will be going back on. Then its a trip to the paint shop tomorrow to try and sort out the dodgy ones...
Edited by Smity42
YOU'RE a dodgy one....
For Tristan:
agreed - grinding back, and exposing the rust - and not treating it at all is a piss weak effort, much can be said about such questionable workmanship
however,
another thought for rust (not removal, but maybe containing?) is when u have a small amount of rust from where the paint cracked when u rolled your guards - simply cover it with some clear nail polish - and it will contain it, until u are ready to remove it and fix it correctly (usually done when car is re-sprayed)
i am going to do this once it stops raining and it is dry ;)
the job you've done in the pics looks quality mang!
ps, also ordered some epic headlights - hopefully ill actaully be able to see more than 10metres in front of me hahahha
That's what she said
however,
Yep, I've been busy fixing all the rust from guard rolling too. I sand the rust off, and then hit it with touch up paint.
But good call on the nail polish, that should stop it rusting at all if you apply it as soon as the paint starts to crack.
im going to dodge the f**k out of you
went zorbing today. was awesome fun. Started the gtr as well. want to drive so bad lol. Ill grab some pics of the new ESSSS AARRRR now.
Speaking of pics. Here is what Dan aka The Legend - did for me today:
Right:
Left:
Front:
Rear:
And not only that. He also got my A/C working!!!! ;)
I drove home with the windows up!!
Thanks heaps Dan! Awesome work :blush:
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
