Im listening
I hate it when you put words in my mouth Nismoh
I see youve played RAPE as well.
It's not rape it's suprise sex :thumbsup:
Shh, Thristan will get upset.
Is everyone still doing "winter" ice cream?
Thristan will understand :thumbsup:
We're there every week you should come and play cars with us Josh
Morning Mangs
Morning
Also a good use of duct tape
The jailbait is there regardless of temperature...
I wanted to play something else with Josh...
I'll come this week if Thristan is still driving me
Sick
Can I wear a scarf if I come?
I'd be disappointed if you didn't accessorise Josh
cheaper option: Duct tape a hose to the trumpet(s)
I had thought about it TBH... will it recirculate well enough to not blow shit up though? or well enough to not cause random stalls making me look like an L or P plater?
Definitely.
If your hose is big enough (that's what she said)
yeah, but does it vent as much through the 'trumpet' as it would through a recirc hose/pipe? Or does it only vent a portion of what a recirc BOV would vent back into the pipe work, and send the rest back to the turbo? I don't really know how atmo valves work to be honest...
afaik, they work exactly the same, just an atmo one dumps the air to atmosphere (usually, but not always, via a trumpet of some sort) while a recirc one runs a hose to dump the air back into the intake.
Guess there's only one way to find out if it'll work then. :happy:
Bingo. We recently had to turn Annas atmo bov to plumbed back and all it required was the right size hydraulic hose (bendy and built to take pressure) and some hose clamps. We tried other hose but it kept getting holes blown in it
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
