Also John hows the SSQ
big, shiny, heavy. waiting for me to obtain tools to put it on. The other one is big, not as shiny, slightly heavier, and waiting for me to talk to Dan about where/how to attach that one (it goes into a pipe somewhere).
Once I've given them both a bit of a thrashing I'll let you know how they work out :(
also - for those who are up on the current what's what with my car.
I'm just waiting on my boost gauge to arrive in the mail :(
allllllso - for anyone to field. Do I really NEED an aftermarket ECU to hit the 300 killerwasps mark?
yeah you do, the stock ecu will start being gay before then, especially given that you will need to change injectors...but the only reason i suggested vipec was because you mentioned getting rid of the afm, if you are happy to keep the afm nistune it.
soooo......
Avatar is a complete piece of boring ass shit. Only good thing about it was getting to see that silly mole Michelle Rodriguez die again. Predictable rehashed phone in hack of a movie.
How do I go about getting back the 2hs 41mins of my life? Does anyone have a flux capacitor?
Avatar's not THAT bad... its the same old story... boy meets girl, boy overcomes challenge, boy gets girl... Pocahontas anyone?
The 3D was pretty I just wish they made 300 in 3D...
head.......... assplode....
so many different ways.
Ok. This week = nistune vs vipec study. Hopefully brain doesn't melt down.
Thanks Andy. I was leaning towards GTR injectors. They should be ok shouldn't they?
nistune is a lot cheaper and more than capable, vipec has a lot of stuff you will probably never use. if you are happy with keeping the AFM i would seriously go the nistune, i wouldnt be able to justify the cost of the vipec. GTR injectors will be plenty for your application.
The graphics really didn't do anything for me. I did like the light up floor... but it was cooler in "Big" because it was a piano then, and original. And as fas as I'm concerned the movie "Field Of Dreams" had MUCH better scenery effects.
The animals were all just... lamepants. Each animal had a different roar of different dinosaurs from Jurassic Park. The black panther thing was the T-Rex, the little coyote things were the Dilophosaurus, the horse things were the raptor "honk" and the birds were the raptor "hiss".
The "helicopters" made NO SENSE AT ALL. If those blades are encased in a big circular shield, then they shouldn't sound like helicopter blades because the tips aren't cutting through the air making that "WHUP WHUP WHUP" sound.
..so... nothing really stood out as original, or groundbreaking. Was just a 3hr story that could have been easily half that. Only that wouldn't have stroked Cameron's ego quite as sufficiently.
and 300 would still have been a terrible movie even if it was in 3D.
Cheers :)
I'll keep that in mind whilst doing my "research" :(
The only reason to watch avatar was at the movies, on the big screen, in 3D. Anything else and it would have just been shit.
Hell it was shit at the movies too, just epic 3D shit :(
i is back from the west.
John:
Make a date, im good for this weekend if you, jason, martin are.
German club wednesday night sounds good.
John:
farkers, i miss out on german club
on a funny side note, on our way to our hotel from the airport in NY, drove past 3 separate sports fields, on 2 of those, people were playing bloody cricket.
these were three separate sports fields in three different suburbs. last thing i expected to see here was cricket.
Exactly, its all it was.. watching it in 2D is like watching a dvd on a 30cm CTV.... cough cough
300 was great for the action, what more do you expect of Spartans?
John:
This weekend probably not great, mothers day on sunday.
I can probably do saturday though if you want
+1
I'm not surprised, cricket is awesome.
What about sexy dave?
is sexy.
SPARTA!!!!!!!!!!!!!!
just back reading, yep john you'll need an ecu/chipped ecu to run 440cc injectors and to make 300hp
agreed vipec would be over kill
aaaaand! agreed sexy dave is so sexy
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
