John, Dan and Tim
Unfortunately I have to work this weekend. Plus side is I finish at 3pm. So I can't do the car thing if it was on in the first place.
Can you let me know if it is or not ?
Tah :P
Dan just msg'd me and apparently he can't make it - so I guess not.
John - FYI if he hasn't told you yet :P
He suggested next sunday, but I can't do that as I have to play in the corporate games. I can do saturday though, but not sure how that works for everyone else.
So, new date pending.
Sincerely,
Tim
I just found the star wars thread in wasteland!
Currently imagining Morgan in the Leia slave girl costume, Tarlae in the tight white Padme costume, and Molly in the Mara Jade costume...
brb
P.S. Yes John, Boba Fett > All.
P.P.S. Dan 'should' be able to do next sat (15th). Hows that work for everyone else?
I'll check and let you know. Sorry about the charger mang. Was gonna bring it Saturday, but I should have brought it last night in case Saturday didn't go ahead.
brb
.........yep, i'd agree with this above statement
Evening gents! Finally got all the nolathane bushes in tonight, only took about half an hour for both rears now that I know what I'm doing.
Next thing to tackle is the rear drum brakes :cool: not looking forward to it.
What's this stuff you're planning Jase?
is she hot?
She's my daughter and she is nine.
What I plan every night Pinky... TRYING TO TAKE OVER THE WORLD!!!! ( with junk mail )
Whats wrong with them? You can fix my XF drums while ur at it...
The question still stands ;)
The question still stands :cool:
Easy now
Mr. Coils : Drum brakes suck balls. You should get some overnight from japan and just bolt them on.
Tim : How many can we have at this turnout ?
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
