I told him you might be unavailable due to hospital stuff, he wasnt worried, he will keep calling till he gets you.
Got back from hospital now. She is on some new pain killers and looks a lot better :P
the awesome part of that is that her husby got appointed as a director of our department, alongside 2 other directors of the old departments, so he gets paid lots but doesnt need to know anything about either department. I guess though to be married to Captain Blight i would want a pretty good sweetner too.
Definitely. But remember to use preferences when voting for greens, they preference to labour :P
Preference to pirate party, sex party, gamer party, and basically everyone else instead.
No I mean. You take my vote, and do it yourself. I'm not voting.
slap slap slap
Well it's going to happen eventually anyway. If not by this one, by the next one. So it's really not worth giving up part of my day and going to a school ON A WEEKEND (if it was weekday and there was JB I'd at least consider it) and wasting my time drawing on paper.
Plus I know NOTHING about politics and refuse to be one of the people who just goes in and donkey votes and screws up the system.
What difference does weekend/weekday make to a jobless bum? :P
howdy
huge morning for old tristan
- wheel alignment with roy
- 2nd wheel alignment with roy (3.5camber made my rim rub on coilover) so now 2.5camber - considering looking for some 2mm spacers if i want to try 3.5 in the future
- new wheels fitted with tyres and balanced
- daily is now insured and in transfered the rego
- i has coronas in the fridge cuz my gf is f**king rad and got me some before
- have another 1000words left in my assignment
SUP WITH YOU GUYS?!
Uni is gaids. Estimating is boring and my lecturer sucks donkey dick. I have proof.
Lol, TRD is tuning everything these days
Hopefully we wont have too many vehicles with dodgy accelerators and dangerous floor mats.
I really need some brakes, as Anna wants mine for the sil80, im thinking R33 brembos, but my mate works for a v8 ute racing team and they run alcons....but would need adapting.
hmm not sure what direction to take, this car has been all about enhancing rather than re-engineering so a bolt on fit does appeal, just not sure they will be enough though!
34 brembos or have a look at the K sport brakes? Decent budget upgrade that is being used by a few people on here without any problems.
Atomicbomberman had some impressive brembo brake calipers with him one night. Ferrari ones or some such. Dan or Martin might remember. He was putting them on his 32GTR and they looked like MORE than enough.
They were 8 pot brembos off a corvette if I remember correctly. He has 360 brakes for the rears.
I missed far too much and was going to quote everything and make an epic post but cbf now. So I'll just say Anna Bligh is f**king retarded and uni is gay.
What difference does weekend/weekday make to a jobless bum? :laugh:
Yeah I don't get it. Whenever I have holidays it takes me about 3 days to forget what day of the week it is. :P
I put it in there originally for the sole reason you wouldn't need to ask why a weekend/weekday was any different.
Attn Gay cowboy aka josh:
I haven't done a cambelt in a 355 but i have seen it done, you will need a hoist and a frame. Removal of the engine and rear suspension subframe is the fastest way to do it, also the easiest, in 360 and later you can remove a panel behind the drivers seat to change the belt. I can give you some names if you want it done for cheap
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
