Martin don't bother. I've decided to go the route of fire now instead of sandblasting.
You're welcome to bring your stuff over to join my metal-burning-non-split-pin-cruise bonfire
Scarnon mangs ?
Forgot to say :(
My sister is at home, no more tubes in her and on some awesome pain killers. She is doing heaps good :P
Great to here mang :laugh: Hope she recovers well.
Lawl at the pics
Skins! Sorry mate i didnt realise that the position we had here at the moment was a part time one, at least when a full time one comes up you will still be known to the powers that be
No worries :laugh: Your boss just rang me... He's pretty keen :P
Thinking about chucking a 6 month long strayen day and trying it out
Great to hear* mang :laugh: Hope she recovers well.
Lawl at the pics
FMP
quick quick someone find josh at ice cream <_<
Too many fatties at ice cream to choose from :P
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
