speaking of nazis has anyone seen that nazi movie with brad pitt in it - i think its called bastard something...
im keen as to get it out
You just have to be a guest of a founding member of the Nazi Party
don't mention the war....check
goose step in the door and "sieg heil" the door man .... check
German club closing BEFORE the silly game ends means that people won't be there to watch the game :) might make GC a winrar!
Keen as mustard, but I think Miso wanted to watch the origin. And we don't want to make Miso angry...
evening children
morning. I left some hate love in your SD thread :D
Do you have to be a member of the german club like rsl's and suchlike ?
Yeah, or you can get in as a members guest.
I'll find my armband...
Don't forget to order the holocaust burger!
^^faulty towers reference - very impressed :)
Welcome to several days ago :P
hulk smash
with a side of jew ?
yay :) weekend all over again
bllllloooooooooooooooooooows
the first scene was like rubbing sand paper on your knob, terrible movie
Inglourios Basterds. I like it - thousands didn't. I have a digital copy of it if you wanna save some money in case you don't like it.
Who are you, and what have you done with John? :blink:
1.5 hours to go :)
Edited by Smity42
1.5 hours to go :D
I knew Inglorious was spelled incorrectly in the title, but couldn't remember how. Turns out it's just an extra U, making it "Inglourious"
I think I've used "wanna" before too :)
@Jason:
Mang, I just realised something definitely isn't adding up with your car. If you are not going to get time to drop round this arvo, can you get pictures of the boost control set up in the engine bay (Near the left hand shock tower, you'll see 2 hoses, from memory 1 red/orange and 1 blue, try to get pic(s) showing where these hoses run to at both ends)
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
