yes!
at the moment its already either just on legal height or just below, i'm trying to get some 16" alfa wheels for it, then maybe lower it a little more.
sounds like a fair deal. Hard to get powers.
Needs more mountain biking i do, my fitness levels are lower then i thought, although its not an easy thing to ride uphills on a bike made only to go downhills. Very fast at downhill though
Sup mangs
Last uni lecture of the semester today. Also hand in my last assignment for the semester so pretty happy. Then I've got a week till my first exam. Should be a relatively chilled week this week. Scarnon with you?
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
    • My mechanic installed all the parts and then got it tuned which i think is around the corner from him
