I may be able to get my hands on some stocker 33 ones. Would that help?
Thanks mang but nah, it's for my mates 32
They dont fit.
FYI I gave away a pair of stocko ones
Damn you hahaha
The flux capacitor has deteriorated causing a feedback interference loop with the syncromesh gear ionisation device, resulting in dilution of the mechanical lubrication fluid, causing it to evaporate in the combustion chamber and/or bypass the piston sealing devices.
Now THAT is technical
Yup
@John: do you still have that squashed stock bov I gave you? I just sold my turbosmart one tonight and thinkin I might put that one back on if you do
Side note: the TRD laser's going in to drift king next week!! Hahaha!!
So, finally figured out what is wrong with Jason's boost control set up.
What's wrong with this picture?
Hint: Symptoms include infinity boost, and (I presume) BOV not working
I can't believe I didn't spot it when I looked last week, my excuse is I was drunk on JB :)
I'll let you all guess for yourselves which 'mechanic' is responsible for this quality work.
martin get an abn, get on a supplier list who happens to source many different brands/parts, and start a business.
ive joined the same supplier with my abn, and did it drunk - so its easy to start...
:D
I've got better things to do with my time. But I'll keep in mind you can hook me up with parts :D
Shitbox 75 had a transaxle with LSD in the boot. f**k yeah, $1000 saved.
Morning mangs, scarnon?
hey marto
cool xf.
needs more;
While it does rip a mean skid, I have 1 2 3 4 other cars that would be better for drifting than it.
That's what she said
Sure do. Come on Thursday and get it :)
Sweet deal..... can't make it this week though, got a dinner with a bunch of people in the valley then going to watch a play at griffith.
PM you who your "supplier" is
I worked for Pizza Capers for 5-6 years..... it's great. I can't eat pizza anymore as a side effect, seeing as I used to eat it 4-7 nights a week
pizza Capers :down:
Hell's Pizza ;) as I now drive past one going home from work
While I agree with you hell's pizza is awesome, capers does not deserve a thumbs down. I do wish there was a hell closer to me though ;)
The local capers seems to have a policy of hiring hotties though, and this I approve of.
I worked for dominos for 6 years, also used to eat it about 4 or more times a week. I can still happily eat it though :)
While I agree with you hell's pizza is awesome, capers does not deserve a thumbs down. I do wish there was a hell closer to me though :down:
I remove the thumbs down as they are good pizza's
Then there's no debate at all. Pizza Capers FTW.
;) but still going to hell's pizza tonight as it's practically a drive through on way home.
Jason's blown a turbo seal from his mega super infinity boosto!
Dam that sucks
pizza Capers :down:
Capers > Hells AINEC
Hotties + Pizza? New destination for thursday night meets?
Sarp Mangs. Hot new graduate started today. It's awesome.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
