That would be cool. Next time I have her I'll let you know. You can come and have a look around anytime but it has to be either on a afternoon 3-11 or a late 11-7.
We should do it on an 11-7 Thursday :sick:
I'll see if I can steal Jack next time you've got her :action-smiley-069:
17th of june ?
as long as you wear a ninja mask when you do it and run away with him under one arm :)
No car... but if anything probably the cheapest thing I can get :sick:
t-shirt ninjas ftw... but not t-shirt ninja pedobear O.o
Martin would like it here... I'm staying at a university college and its full of not-quite JB. :action-smiley-069:
correction: they've just finished exams, so make that very drunk not-quite JB.
Edited by GTTG
irection!!
Will Geoff deliver ? :sick:
Will Jason fall asleep at work ?
Will John get his Ninja shirt ?
Will Tim enjoy his breakfast and will Colin ever be able to go near a 20 watt bulb without getting 3rd degree burns?
Stay tuned...
see this is why we need msn... you don't say that kind of stuff there. You just ask me to turn on my cam :action-smiley-069:
Yeah but that's different. We wear wizard hats and robes when we msn. In here I go pantless.
Doesn't have the same feel. :sick:
I'm calling it a day, so I bid you good evening, gentlemen.
Nothing stopping you both breaking out those wizards hats after all.... maybe even the cookie-wands?
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
