sup mangs. New dirty 30 has been acquired. Dad reckons bit of sump damage getting it out of the car :S Will check the pick up and make sure it is sweet if not I have a spare from the dead motor lol. He also said looks like it may have had some work done recently. Core plugs in the side of the block all look fairly new and so does the thermostat.
f**k yeah!
What's new guys?
I have a license martin, you give me his details and pay my travel expenses and i will deal with the matter and get you your porker brakes
His name is nik (yes nik) and he lives in south yarra somewhere. k go
f**k yeah!
What's new guys?
RAVBAT! Scarnon mang, we missed you :down:
that f**kin sucks Mcfly :) Sexy brakes those ones aswell.
Boring day at work today got a fair bit done though. Day off/uni tomorrow though :O Also mangs does anyone have a clutch alignment tool and/or a torque wrench I can borrow?
RAVBAT! Scarnon mang, we missed you :O
And I, you! :)
f*cking paypal are giving him another 10 days to respond before they 'decide on out outcome'
its already been 2 weeks since i last got a message from him!!!!
Megaepicpaypalfail...... I hate red tape like the plague
If anyone's interested, I got the new laser roadworthied last week and transfered to my name.... done all the usual shit since, oil + filter, new radiator & coolant, she runs great now! Just have to adjust the carby so it idles a little higher once warm and I'll be pretty happy with it!
And I, you! :)
bring it out for ice cream so we can see it! Tristan brought the TRD Mazda to show us. Epic dish :O
yes and maybe
Sweet
Yeah paypal are f**ked...
And I, you! ;)
Sickness mang. Just needs more Baskins :D
colin i got a clutch aligning tool, will bring tommorrow
:O
hard drive cleanup!
Yeah mine could use a good clean but I'm scared of what I'll find if I go poking around in there :)
i found stuff i thought i'd lost...... :O happy times!
complete format and reinstall of my system, runs so much faster now it doesn't have so much crap on it
speaking of tracks
got a copy of Forza 3 the other day and finally got a chance to play it today. Pretty awesome game. The drifting bit takes a bit of practice... I totally munted the mines R34 drifting it up some mountain in Fujiama or something. Good selection of cars in it from what I've seen so far :P
speaking of tracks
for the xbox 360 ?
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
