Haven't posted in a while, I know you've all missed me. Moved out and haven't got around to calling up tpg yet, however I "gained" access to another network in the area.
Looking at importing a car in the next few, so many choices!
Welcome back :D
That 33 still dead?
What's top of the list?
RE porka brakes:
We have concluded our investigation into your case and have decided in your favour.
We were able to recover $530.00 AUD, and this amount has been credited to you. Please allow five business days
I really wanted those brakes, but at least im not out 500 bux I guess...
Welcome back :domokun:
That 33 still dead?
Hahah, replaced the coil pack, wiring loom and the spark plug and shes all go again. I told him to go get a series 1 coil pack, and wiring loom.
He came back with a series 1 coil pack and a series 2 loom.
Im thinking either 32 gtr or 34 gt r or gtt. Since its my first car off my p plates Ive been leaning more toward the gtt.
By the way, anyone who uses firefox here, when theyre replying to something and hit the apostrophe key does it bring up a find field?
at least it's all fixed now
are you sure you need to import a 34? there's a fair few of them here already. Fair enough if it's going to save you a heap of money, but otherwise it might be better to buy local?
no search field for me
I don't think it would even save you money importing a 34. All the skylines have been brought over in large numbers you may aswell buy one local since they are as cheap if not cheaper over here anyway. Only way you would want to import one is if it was a one off, low ks full logbooks collectors item.
Morning mangs
Morning mangs
Your up early.
How was the weekend ?
Your up early.
Up this time every morning :banana: Normally its a lot busier in the morning so I don't post until all my subbies are started work etc. Hardly got anyone working today :banana:
Weekend was a great success :)
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
