Finally some clear weather, so got the skyline out instead of the vw.
Driving the skyline in the wet is a major pain in the ass, as the demisters are rubbish and there is no air con, so usually have to drive with the window open, getting rained on...
And that's winthout mentioning the $80 a pop, plastic rear, barely can be called, tyres
Edited by PWND
My windscreen wiper has an issue where it sometimes scrapes the windscreen, quite annoying when you're sitting in traffic, you're ipod is dead, no good cds in the car and all you can hear is metal scraping glass.
My drivers side window also doesn't go up which is awesome for surprise storms.
Don't get me started about driving in the rain lol. The 31 has no heater or A/C and 1 window is never enough to stop the windscreen from fogging up so I end up with all the windows open. My lights are shithouse normally add rain into the mix and I can see about a metre infront of the car for everything else I have to use the force. Can't see out of the back window because of shit tint left over. The wipers are f**ked and seem to readjust whenever they please so one minute they will be fine next they won't make it over to the drivers side or they overshoot it and go off the windscreen entirely.
Certainly makes driving in the rain an adventure...
My 31 is just as pleasant to drive in the rain as it is in the dry
My 32 is good too. Just not when I have to cross epic rivers. The air con demists the rear window, so it doesn't matter that the rear demister doesn't work :banana:
Lol, what an evening. Was feeling energetic this afternoon and decided to tape up the coil packs on the 33, it had a flat battery as well so I went and picked up some jumper cables from a mate and jump started the car. Went out for a drive up to the servo in warner/bray park to pump tyres up. Car just started after putting some petrol in, gave it a bit of a boot to see how the coil packs went now that we'd fixed them up, was all sunshine and roses. Until the car started hunting.
Someone forgot to tighten a hose clamp up.
Had no flat head screwdriver so we called home and got someone to bring my car out, got the car and fixed up the hose clamp. Now my bonnet doesn't open so we were trying to flag down a car. A black 32 drove past us, kept going, a multitude of other cars as well as a white stagea who did a skid around the roundabout and then got chased by an undercover car. So thanks to those two drivers for pulling over! lol. In the end a hot little p plater pulled over and we got it all going :banana:
*Stamp* APPROVED
Got this link in a email from Dad this morning lol. As good as the learn to speak Jap chick for sure.
*Stamp* APPROVED
learn to speak jap chick has nudes thus = better
I could only find shit pics that may or may not be her. I fail at internets. I demand that you share!
Question of the day - if you could swap your car for anything within reason (say 20k+ the value of your current vehicle) what would it be?
Mine? A very clean 32 GTR or 34 GTR.
My car with +20k spent on engine mods
In order of preference:
240Z fully restored + turbo L28 conversion
32GTR with a lot of work done
350Z + turbo conversion
Z32 2+0 twin turbo targa top
S2000
Bongo van
S2000
you beat me to it John
Mine is 240z, with either a rb26 or similar.
Currently in the market for a reasonable 240z shell :banana:
im actually the same as Martin, I would like another 20k to sink into mine for brakes, new suspension, track rubber, carbon bits and maybe some bigger turbos :banana:
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
