I wondered what that text message was about, Joe :P
That car came apart surprisingly fast too! Did it go back together as quickly? :)
Haha well i dunno how long it took you lol but there were 4 of you!
Felt stupid this morning when i didnt realise thats where u had been last night lol the widscreen wipers were the hardest because i had to get em on the splines on the right position agen lol
Took me a couple of minutes to find the lead off the distributor (F**KERS! LOL) I checked the fuse box first
Finally found the hot ranga that i know! Hair doesnt look that red there but it is
WIN!! invite her to baskins next week wether its the same one or not lol
surely it's close? Morning Mangs,
Strayen day today need to get uni assignment finished. I don't think it fully qualifies as a strayen day though.
That reminds me I need to pre-book some not-quite-strayen days for the mondays after the last two F1 rounds...
Why is this?
Why is this?
The penultimate race is on at 2 in the morning or some shiz and I don't want to go to work the next day. Also it's the day after my birthday.
The last race is on an hour later than normal (which is already too damn late when you start work at 7am), and there will be much drinking and celebrations when Mahk Wibbah wins the WDC. So once again, don't want to go to work the next day.
But two Mondays in a row as 'strayen days would raise too many eyebrows, so I'm just going to take leave. I have sh*tloads anyway.
Is there beer available?
Thanks Dan for coming over yesterday to try and get these studs out... no luck though. So right now I need to organise:
1) New battery
2) Tow to workshop
3) Workshop replaces studs/hubs/whatever is needed
Yayyyy
1) New battery
2) Tow to workshop
Yayyyy
Can possibly assist towing with sexF if you need... You'd have to hire a trailer though
