Don't get verdes.
Why?
I wanna be ballllllllerrrrr
Just got a glowing performance review despite the fact i have done very little for the last 6 months! Win!
Sounds like my job hahahaha
Yeah brakes are next on my list. And the cat + front pipes fitted. Will have to wait for a bit though since I'm all out of money again after buying 4 new tyres and rego + insurance on the GTR.
yes that would add up!
I cant decide what to do brakes wise, the Ksports look pretty good....but all my other stuff is brandwhore...but brakes inparticular seem to carry a massive brand tax. though with the Aus dollar so good willwood and stoptech become pretty good options
Have you had a look at the porche brembos? Another one that would be worthwhile looking at while the dollar is up there. Have a look on ebay the only thing is getting the adapters made up etc. The stoptech brakes look like a good package aswell though and less f**king around.
Im all for no f**king around!
I think Ksport has the inside running at the moment, I saw so many cars using them to great effect down at superlap and everything i need gets delivered to my door, If i could find a decent set of r33 GTR brembos I would use them but every one wants too much, Its really making me regret that i didnt hold on to the set i had on the old R32 for longer. I had them in my garage for ages but them swapped them for the engine in Annas car.
Rotas are reasonably cheep. Could try them? Atleast they copy some nice looking wheels. Or have a look at the advanti rims that option 1 sell.
Yeah ideally I want some white thin 5 spoke ones... or some chrome/shadow chrome like my old ones.
But lately I've liked the idea of filling the entire space with some massive chrome bling dinner plate style thing....... so ridiculous....... so beautiful......... *sheds a tear*
you could sell the ones you have though right? Change over wouldnt be so bad
The ones in my pic were sold a few months ago...... I'm running 16" wheels that are similar to stockos at the moment
Godf**kingdamnit I hope this is sarcasm :D
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
