2011 blue premium, expect delivery in March at this stage...
I should elaborate its not mine as in im not paying for it, but its living with me... :ninja:
Lucky bastard. Bring it out on thursdays? that'll draw a crowd.
One thing I dislike about christmas is all the time off, I don't get holiday pay.
So fingers crossed, changing employers early next year, 32 not too far after that. Exciiiited.
Fckin Dreamworld rollover popup wreck my shit advertisment.
Morning Mangs!
2 days to go... :(
New GT5 patch is win.
/me is fairly jealous. Lucky SOB.
Interested to hear this story...
Do it.
Sucks to be you. I has 2 weeks off with pay :)
Edited by Smity42
Divisional President/CEO/ Boss thingy is visiting from the states to have morning tea. Do you think this will be good news or bad?
depends... did you smash the back out of his wife/daughter?
Speaking of bits under the dash.
I'll have to take a look at mine, as I'm only getting hot air blowing through.
what about all the bits up under the dash? :P
Yeap, all gone
If you need any parts, give me a pm
man I will never understand removing aircon, we live in QLD ffs, My aircon is on the fritz and its driving me nuts! Unless it is a track only car removing functioning aircon is fail
Agreed.
I copped a lot of shit when I kept the aircon in my car when I rebuilt it. F*ck em, it's QLD and it gets hot.
I suspect TwoCents' pintara the air con didn't work and that's why he's removing it ;). Why? It's a 31, the air con never works...
Spewin I missed out on a couple of good steam specials yesterday :(. Todays ones are sh*t.
Agreed.
Its not the pintara thats getting stripped... its aircon just needs a regas.
Tbh ive only used the aircon in the 33 about 4 times since ive owned it... and thats because passangers wanted it on.
pray your windows dont fog up in the future then, no demister! lol
I use to be an A/C hater, because mine never worked, but honestly would never go back to not having it.
Andy whats wrong with your a/c? does it just need a regas or have you got a leak, cause im good with fixing a/c systems.
I only ever use my aircon when it's raining. All other times I have the window down so I can hang my arm down the side of the door, I just need to own a VN and I'll fit right in.
