It sure is. I'm running the show today :whistling:
Oh btw I pressurised my intake piping last night, all my clamps etc were fine. The only thing I found was the line going to my boost gauge seems to be leaking. I unhooked it from the plenum and did it again, the only sound was now coming from that hookup at the back of the plenum. So some more vacuum hose on the way home from work this arvo and we'll see how she goes tonight.
Could that really be causing a few psi to leak though?
That's what happen to my car on the weekend, had no boost at all via the gauge, but car was fine, new hose and she's sweet. I suppose every little bit helps.
I have a leak somewhere too! Was driving along the other night and gave it its first real bootful for a few weeks and as it came on boost it sounded like a stock RB25 turbo (Ie Vaccume cleaner) and was slow as hell, Drives fine normally but so im gussing a split some where that blows open under high pressure then seals up ok at low pressure.
It could certainly make you guage read many PSI lower.
Would also potentially affect how the car runs. Anything with an AFM (ie skylines) will be particularly sensitive to boost/vac leaks.
Oh and screw black ops, get this into ya
Nice.
I removed my AFM and replaced it with a full baked bean can (clamp it in tight)
Then I pulled the cooler piping -> actuator vacuum hose and replaced it (on the piping nipple) with a bike tyre valve on a piece of hose and all clamped tight, then hooked that up the my compressor set @ 10psi.
Worked a treat, cost me $7 hahaha.
Oh, plus the baked beans. But now I'm gonna have them for lunch so it's win-win!
Edited by mosquitocoils
Tas called me last night and wanted to catch up. So i said yeah meet me near my place. So I walk down to the car park and there he is standing next to a black guy. I'm like its midnight, abandoned carpark with an asian and a black guy. Yep totally legit. Then after a bit 3 cop cars come out of nowhere arrest some drunk guy down the street. Then keep doing circles around the block obviously looking for some other guy but oddly enough driving past us (the legit guys) very slowly. Fun times.
P.s. The black guy was Shan and yes he is very black.
The end.
LOL having an accidental strayan day today. Strayan days so awesome.
The end.
Ahahaha Shan, the darkness.
Accidental Strayan Day FTW.
What did you get defected for?
AHAHAHAHA! F*ck I laughed at that. You should definitely own a 31 bro.
HAHAHA yeah I thought it was a great idea... I actually got it off this very site...
Is this the same old one? Or a NEW defect??
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
