do you guys ever meet up for a cruise etc?? ive noticed a lot of ppl meet up on thursday nights (bad for me coz i gotta work haha)
Sarp mangs.
Might have been me Andy. I was on the riverside expressway around 11:30ish i think coming back from uni. If it was on the ICB like near Hale street it wasn't me.
Final uni assignment for the semester finished. Kind of. 26k words between 5 of us. I've churned out 6k words in a about 8 hours lol. Sooo over it.
It would seem you have a GTR twin, same wheels and all.
Clearly you are an excellent judge of talent, however the target score would have prevented me from achieving this feat.
haha
Every one would have been happy to let you keep going
WHAT THE f**k IS WITH HUNGRY JACKS NOT SELLING THE AUSSIE BURGER ANY MORE????!?!!?!?!?!?!!
It's un-Australian.
Thats f**ked, it was my favorite.
Morning Mangs
I know, right!
Check out the events section for our big yearly cruise on the 20th of November.
Other than that, smaller cruises are sometimes organised at the Thursday night meets. Sometimes they get put on the forum, sometimes they don't.
Yes, he does. I've seen it a few times at Chermside. Spun me out the first time I saw it!
they guy driving it even appears to be a ranga with short hair
I did see a girl driving the car at Chermside one time... maybe that means that future Colin comes from a society where girls will actually touch rangas? That's a scary thought... I don't know if I want to live in that kind of future :huh:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
