Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
An interesting counter argument. But, I put it to you sir, you sucked off a horse.
Well put sir, however:
Ladies and gentlemen, this is Chewbacca. Chewbacca is a Wookiee from the planet Kashyyyk. But Chewbacca lives on the planet Endor. Now think about it; that does not make sense!
Why would a Wookiee, an eight-foot tall Wookiee, want to live on Endor, with a bunch of two-foot tall Ewoks? That does not make sense! But more important, you have to ask yourself: What does this have to do with this case? Nothing. Ladies and gentlemen, it has nothing to do with this case! It does not make sense! Look at me. I'm a lawyer defending a major record company, and I'm talkin' about Chewbacca! Does that make sense? Ladies and gentlemen, I am not making any sense! None of this makes sense! And so you have to remember, when you're in that jury room deliberatin' and conjugatin' the Emancipation Proclamation, does it make sense? No! Ladies and gentlemen of this supposed jury, it does not make sense! If Chewbacca lives on Endor, you must acquit! The defense rests.
I know how to settle on a winner.
Who's the guy in the photo? There's your winner right there :ermm:
there's a guy in that photo?!
Hahahaha well Tristan's been mentoring me so this weekend hopefully we'll have some BEWBBBBBBBS to report in with hahahaha
Having said that, I'm not sure how good T-dawg is with the ladies :)
Seeing as how tristan always promised to bring us scene bitches and never delivered... and never gave us bewbs... I'd say you're probably going to get slapped this weekend :P
nah im flagging it, that was hard lol
that's what she said
you suck
no you suck!
that's what she said in return.
after a brief tickle fight... they sucked it together.
It looks a lot like my old 32...except a shitter blue:P Oh and i had far cooler looking brakes :ermm:
Its not about the going home its about the nailing the ass out of them when you get there, if this wasnt the case this story and excitement needs to end now because it saddens me
1. Thinking I might have to paint my callipers when I get my new rims.
2. +1 doesn't even begin to agree with this statement
I really wanna paint my calipers too, just really cbf doing it. Any recommendations on paint brand etc?
Can't really make out the purple in that picture, so they can't be THAT gay.
PS - what are those side skirts?
yeah pic is too fuzzy, in real life they were pretty bad
i think the skirts were a factory option or somthing, lots of GTSTs have them, i think they mostly came on the ones that had the cool mechanised front lip, we call them Mspec but i dont think thats what nissan called them! this car here has the same ones, as did many others when i had a quick google image search http://www.mashamoto.co.uk/be/image/Sold%2...09/CIMG0950.JPG
Coooool! I like the look of those. I like the look of that front bar on that one in the link too.
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
