Are you sure you're playing the right game? Resident evil 5 is like resident evil 4. it's nothing at all like 1 & 2, code veronica etc etc etc. You can't even run and gun in this. Oh yeah there are "zombies" (not even really zombies) coming towards me and i can't run at them with my machete i have to stand there like a dumb flamin mongrel and hack in mid air until they get to me....... FAIL :P
No puzzles either. Oh wait yes there is that dumb mirror 'puzzle' that took me about a whole 15 seconds to do. It wasn't even "scary." This game and capcom suck dick
i only played RE5 for like 5 minutes... as soon as i got to a scene where i had to fight zombies and realised you cant run or move at all while using a gun i turned it off and put COD5 back on.
I was a bit disappointed myself. I'm a huge Res fan and had them all on PS2. Since upgrading to the PS3 I bought Res5 and It's just a basic 3rd person shooter. Yeah Chris and Jill were back but where's the creepy old mansions at night with lightning and The moaning zombies you can't see cause of the fixed camera ? As has been said the puzzles were pathetic compared to old RE games. As a random 3rd Shooter 7/10 but for a resident evil game 3/10
....If only the PS3 was backwards compatible
it is, depends what version you have :)
  • 6 months later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
