up for grabs ,swop is my baby its a very very rare car atm there are only 8 for sale aust wide and where only 100built pritty much a
factory street legal racing car. unlike hsv ect it has koni suspention and racing gear high end stuff .reson for sale need a smaller car willing to trade swop
1999 vt si valanti series 2 corsa
masive 290kw sock car can hack up to 400kw esy more power than the vz r8 hsv
koni suspenion
17 rims good tyers
couler tungsten
custom csv body kit with custom car bra
custom stainless exsorst system comes out midel of car eg like bat mans car lol
leather and fabric seats
6 speed racing gear box same as race cars have
climet
cruse
lazer maped 5.7lv8 worked at factory
tint
log books
full eltrics
floor mats ect
just had $2000 full over hall
new oils coolnt.belts
plugs leads the works
.pritty much car is val at over $25000-30.000
due to masiv price dif car is not being sold with rego our rwc unless its car/cash trade
willing to swop for sumthing mech sound good km good mods looks good and safe car
for gf to drive to
can mms pics to mobs
im in melbourne vic more than happy to work deal out
going at majer loss just to big for what we need
(0421576411) note needs to be gone with in 3 weeks everything for rwc comes with the car tuns heads annywhere u got and qwicker than anny vy vz
and its stock factory car :)
best to mms offer to my mob our qwestions thanks
Edited by mordor22
sounds pretty unique mate! Any pics?
Please run spell check before posting anything again hehe. You even misspelt the model name- its spelt "VOLANTI" not "valanti"- this is the same in your carsales add :P
yerp no probs man on me mob so its bit bodgy .
it is and thats why i brought it now its to big for what we need
annywhere i go people look i have pics via mms only so if sumone sms me il send them .and if sumone could host them would be good
as .i only have the net on me shitty phone .
and i have pics of when car was firts built to from the guy at csv who built it :D how legit this car is sumone must wont kick ars beast
car is now on ebay with full specs and pics car will be sold 10 day swop auction . starts at 17.000 thats half what its worth best deal gets it
typ csv under cars on ebay
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
