FOR SALE 1994 R32 GTR skyline
Gunmetal Grey Duco
Croydon racing developments and perry engineering played a part supplying and building the engine!
aprrox 15000K's since rebuild
R33 Block (chemically cleaned, rebored and honed, surface ground and crack tested, tunnel bored 7 main tunnels)
R33 Crank (crack tested, machined and balanced)
Race series conrod and main bearings
Forged Pistons
Rebuilt Head (machined, pressure tested)
Tomei oil restrictor
ARP head stud kit
ARP rod bolts
Custom 7.5ltr sump with tomei baffle
Complete tomei gasket kit (including metal headgasket)
*engine has alot more bit like new welsh plugs ect all listed on receipts*
Gates timing belt
Tomei Cams
OS giken cam gears
N1 oil pump
SARD 700cc inj
K&N element filter
Stainless engine pipe
Stainless dumps/front
Full 3inch system (very quiet but gives a nice note)
R34 BB turbos
Remapped ECU
NEW fuel pump (was told its a GTR pump but sounds a bit loud to be a stocker)
engine bay has been cleaned up was polished bits n bright red bits but removed nearly all pipe works covers and have now been painted in satin black engine enamel i even replaced the pod filters with a stock airbox and new element filter, just looks alot neater imo
Currently making 280rwkw @ 15psi (this engine was making 370awkw with hks turbo set up unsure what turbos it was running)
dyno sheets for both
New extreme clutch and machined flywheel (with new master and slave cylinder)
5 speed gearbox (receipt for being stripped down and checked, replaced shift keys pivot ball and 4th gear syncro)
Tein coilovers
Whiteline Swaybar nolathane link bushs
all New nolathane bushs for rear arms (not yet installed will come with car)
R33 GTR Wheels
New slotted DBA rotors
New pads
Tint
Alarm/immobilser
Aftermarket steering wheel
Switchs for ABS, RWD and thermos
Torque split controller
Digital speedo/0-400 timer
TKO 300+ speedo
this car comes with many modifications and many replaced parts, Receipts for nearly all the work that has been done including the basics in past years like cv boots/steering rack boots ect all i wanted to do to finish her off was Z32 AFM's a bigger fuel pump and i would recommend -5's and she will be a weapon!
this took me more then 6 months to find and for ppl who know me and know how much of a impulse buyer i am they will realise i waiting for something amazing this time! selling due to finances, i work at holdens and will be going back to day shift but it maybe 1 week on 1 week off which will cut my pay rather badly but i want to clear my debts and hopefully buy a block of land in a new development area near me so clear this loan i should be able to scrape through for the land :s i dont really want to sell but sometimes you gotta make sacrifices :nyaanyaa:
Car is located in Adelaide (northern suburbs)
asking $22,500
PM me if interested!
Edited by shy_s6
https://www.sau.com.au/forums/topic/264393-for-sale-94-r32-gtr-gunmetal-grey/
  • Replies 60
Hi,
I'm trying to get in contact but can't because I just signed up here and need to get 10 posts :)
will make an offer as soon as i can get in contact, im in perth, finances all in order just looking for the right 32gtr.
Hi,
no drama's bud she is still for sale many offers but nothing that will help me out finacially
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
